Message 11 of 21
Re: Printers cant find BT Hub
Probably of no consolation, but I have an Epson 2810 Eco tank printer that connects just fine to a Smart Hub2.
Message 12 of 21
Similarly. I too have a wireless Epson printer 442 series that has always connected seamlessly to my various Hub's LAN. Mine, like others I suspect has a small illuminated screen that contains a set up process assuming one hasn't already used your computer's 'Add a printer' feature.
Message 13 of 21
I did try and set up using the method specified on Epson Support. Didn’t work and I don’t have a cable. I really don’t have the time to faff around trying to work out what cable to get - but also, that’s no use to me as it won’t fix the problem re the WiFi and I don’t want a printer that will only work if plugged in with cables.
Message 14 of 21
I don’t have anything on 2.4 GHz. We had a number of power cuts recently and I think it was after these that I couldn’t get the HP to connect. I’m wondering whether that could have affected the 2.4 GHz in the Hub (eg power surge) but that seems very unlikely. As far as I can tell from the Hub, it says it is working.
my next solution would be to try a new hub but I’m not sure how easy it is to get hold of one from BT?
Message 15 of 21
You can buy one from Amazon. I did for about £27 for experimental purposes.
Message 16 of 21
Download a wifi analyser onto your Smartphone and scan for networks to see if you hub is transmitting both 2.4 and 5 signals.
Message 17 of 21
They’ve agreed to send me a new Hub - they seemed to accept that was the next trouble-shooting step.
Message 18 of 21
Might be worth buying a cable too - very very simple to find out which you need. I use one to my printer in my office and even when I take my lap top to do colour printing in another room it is always just simpler to use the cable in that room too although my sons use wifi for that one usually (I don't have a hub 2 - just an older hub)
Message 19 of 21
Of course it isn't simpler to use a cable. Why on earth would you want to faff about with a cable when you can print from anywhere with WiFi?
Message 20 of 21
Precisely although I often have to get up to see the results on the other room where my wireless printer is.
