Message 1 of 24
Replacement router Asus DSL-ax82u
Hello, i have searched high and low for an answer to this, none of the prvious posts seem to cover my issues.
i recently replaced my modem/router with an Asus DSL-ax82u, i already use an after market router a tp link device. i have replicated the settings on the new asus modem and it seems to be connected but i still dont have internet acess for some reason.
i can comfirm its nothing silly like WIFI or anything this is all fine. it seems to be some advanced setting i dont understand perhaps.
just to make it clear its not a g.fast line or vdsl, its an old copper line type connection.
i have included screenshots from the old modem that i can comfirm is working and the new asus device config screen.
any help resolving this issue would be much appriciated.
Screenshot 2024-02-24 083757.pngScreenshot 2024-02-24 083729.pngScreenshot 2024-02-24 090319.pngScreenshot 2024-02-24 090326.pngScreenshot 2024-02-24 090338.png
23 REPLIES 23
Message 2 of 24
Re: Replacement router Asus DSL-ax82u
user should be [email protected]
and any password
Message 3 of 24
I have tried this already, and also this username and password appears to work on the old modem just fine.
already elminated this as a potential issue, i set it the same as the old one as i knew that this was working.
Message 4 of 24
What are the other options on the WAN type dropdown and Service category dropdown?
Message 5 of 24
ADSL and VDSL
also i have tried both, annoyingly the connection seems to be up but no internet acess?
Message 6 of 24
How are you setting up the router, via Wifi or Ethernet?
Are your devices getting their IP addresses ok from it? Maybe double check its LAN/DHCP settings too?
Message 7 of 24
Im logged inot the router VIA WIFI
i shall have a check but i do believe all this is ok ....
Message 8 of 24
Maybe test a device via Ethernet instead, to see if it gets an internet connection?
Message 9 of 24
I have tried a ping directly from the new device that confirms no connection 😩
Message 10 of 24
You are definitely getting DSL connectivity from the stats so the problem lies with the higher layers.
What are the other options for service category?
