Message 1 of 4
Qnap VPN File Server Through BT Smart Hub
Firstly this is a temporary situation resulting in having to work from home and having a Qnap File Server that we need to share with 3 other employees.
So residential fibre connection through a BT smartHub.
I have set up on the Qnap software (Qvpn) a VPN L2TP/IPSec Server as per the Qnap Instructions.
I set up port forwarding on the BT Hub as per instructions, with the three ports as stated in the Qnap documents.
I can connect to the Qnap from my computer using the internal (Fixed) IP address via the VPN. But when ever i try to make a connection from externally, (using my router external IP Address) I am getting an error message to say that the route is blocked.
Tried the restart of the router.
Any suggestions, am I missing something?
3 REPLIES 3
Message 2 of 4
Re: Qnap VPN File Server Through BT Smart Hub
How are you trying to access the external address? From a device on your LAN or from an external device? The former probably won't work. Try from a mobile connected to 4G rather than your WiFi.
Message 3 of 4
Have used mobile phone (remembered to switch off wi-fi!) and also one of the employees tried from their home.
Neither worked.. 😞
I always understood that you can not test the connection without it been from a proper external source.
Message 4 of 4
I take it you've changed the firewall to allow unsolicited incoming connections?
