Message 1 of 2
Questions about factory reset button on hub
Hi everyone
Just a quick question to ask, when the small button on the back of the hub is pressed in to factory reset it, does this reset any changes made to SSID and passwords?
I only ask because I'm getting a new sh2 soon and I want to know if a factory reset will erase the custom ssid and passwords I input.
thank you.
1 REPLY 1
Message 2 of 2
Re: Questions about factory reset button on hub
A factory reset returns every setting back to the factory settings including SSid and passwords.
