Message 1 of 3
Re: BT Smart Hub 2
I am on BT 500 with an SH2. My speeds are 500 ethernet and 225 wireless. What benefits would I get from purchasing an EE router on Ebay?
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 2
Some here will say probably not much benefit.
If you were to Google what is a WiFi6 router, it’ll tell you far better than a bunch of words here would.
An EE router will cost you £20 new on eBay. You could purchase one and see for yourself whether it gives you any benefit over the SH2.
Message 3 of 3
Re: BT Smart Hub 2
Your devices need to be WiFi 6 capable to get the full benefit from wifi6 router. Older WiFi 5 devices will still work perfectly well with wifi6 router just not get full benefits
