Message 1 of 3
Re: BT settings For ASUS DSL-AC68U
Was this customer on fttp or copper line?
If fttp did he have digital voice?
I want to move to a different router but have fttp and Dv.
Where do you find the settings 1st used I know you say hub but what part?
Thank you
BT Fibre to the premise's customer.
Best Regards
Kev
2 REPLIES 2
Message 2 of 3
I have moved your post to start your own thread as it is not really relevant to the thread you posted on.
Message 3 of 3
To use Digital Voice you have to use the BT smart hub connected directly to the ONT.
If you wish to use a third party router you will need to create a second sub- network.
Have a read through this  thread.
