Message 11 of 14
Re: CONNECTING HH6 SLAVE HUB TO BT FULL FIBRE 500
Thank you for your patience
i seem to be missing something, just not working for me…..
I have a MacBook Pro…….
Connect this too HH6 router with Ethernet
Type 192.168.1.254
use wifi on MacBook to make changed to router
192.168.1.10 etc
is this correct
might be time to get abacus out
Message 12 of 14
No, you disconnect the WiFi first so that ONLY the HH6 is connected. If you're connected to the main network by WiFi you're probably changing the address of the primary router. So that may need changing back.
Message 13 of 14
No worries
Totally lost now
gonna but a Wifi extender instead
thank you for all your help
much appreciated
Message 14 of 14
Thank you for all your help
Finally  got sorted this morning
