Message 11 of 13
Re: Smart hub 2 not allowing local traffic
@imjollywrote:
the new SH2 like any new router will come with it's own SSID (name) and wifi password.  if you receive a new hub then your wifi devices will not connect if you are still using the SSID and wifi password of previous hub
try going to hub manager then setting and scroll down and make sure the ethernet port 4 is marked as not FTTP as you are on FTTC
these FAQ on the forum will help you
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
Thank you. I can understand the matter of (changing/matching) wifi password, but the network I have (in normal/regular use) is just Ethernet (wired). If I needed to use an extra or different device I just swap a plug over at one one end or the other.
Message 12 of 13
with your move to digital voice a mobile would be good advice for emergency use in a power cut or loss of internet connection
Message 13 of 13
Yes, I do have a simple mobile phone but there is a local signal coverage issue (affecting all networks), so it is unfortunately unreliable. Such is life!
