Message 1 of 2
Re: Unable to connect to WWW using ethernet
help
no default gateway is showing for ethernet adaptor
1 REPLY 1
Message 2 of 2
If it's set as a static address you will need to enter the gateway address manually.  It's 192.168.1.254 for the Smart Hub.
