Message 1 of 8
Flatter plug?
The plug for my Openreach junction box (the one before the router) is so big that it is causing an issue with furniture.
The plug says it is:
- 100-240V
- 50/60Hz
- 6.0W
- 12.0V
- 0.5A
Has anyone replaced this plug with a flatter one? Is there an option on sale?Screenshot 2026-09-02 at 13.13.47.png
7 REPLIES 7
Message 2 of 8
Re: Flatter plug?
that is not just an ordinary plug but specific to your ONT.  You could connect a  2 way trailing extension and connect the ONT plug to the extension
Message 3 of 8
Re: Flatter plug?
That's not going to be suited to the challenge I have, sadly. It's a shame that the plug is so big. It's causing a big issue.
Message 4 of 8
Re: Flatter plug?
It's not just a plug of course - it has a transformer in it with the voltage output required by the ONT. There won't be any "flatter" versions available I'm afraid.
Message 5 of 8
Re: Flatter plug?
Just for future reference, the box is called an ONT (Optical Network Terminal).  The plug is actually a low voltage PSU (Power Supply Unit), rather than a simple plug.  I have the same type and I've just measured it.  It stands 1" higher than a normal plug, so I'm not sure how that is a challenge.
If you can be a bit clearer about what this "challenge" is we may be able to offer a better solution.
Message 6 of 8
Re: Flatter plug?
Get a competent person/electrician to extend the cable so that you can plug it into another electrical socket or get Openreach out to move the ONT to a different location where size of the plug won't be an issue. It will cost you about £150 or more to do that.
Message 7 of 8
Re: Flatter plug?
With at least most of our ONTs using a common socket size (unlike the SmartHub 2) you could change to a 12V power adapter that runs from a regular UK 3 pin plug to a figure 8 or clover-leaf socket.  With just 2A being required, you'll be better off getting a 'quality' switching supply, but they are easily available on-line.  Cannot stress enough that the power supply needs to be designed for either IT or medical use, so don't just get the cheapest one going!  *I would not consider this type of adapter to be pet friendly - due to chewing!
You can also get compatible power supplies that are just flatter - probably about twice the height of a standard UK plug!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 8 of 8
Re: Flatter plug?
Probably easier to just rearrange your furniture
