Message 1 of 4
Re: 'Upgraded' to 900 MPS - BT sent us another Smart Hub 2?
I thought the Smart Hub 2 was their latest router! How do you go about getting the new EE ones?
Cannot stand the SH2, so slow, so buggy, terrible UI and UX..
cheers
3 REPLIES 3
Message 2 of 4
The only way to get one of the newer EE routers is to buy of eBay about £30/40
The EE WIFI7 router has been having problems recently due to recent firmware update.  I am sure EE will update firmware to correct problem
Anonymous
Not applicable
Message 3 of 4
 Unless you're a real power user I would think seriously about upgrading to 900mbps.  If you're currently on 300mbps or above it really won't be a eureka moment when you actually get 900mbps.
Message 4 of 4
How much of a power user would you need to be?  I can honestly say having had 900Mbps for just over 2 years, the only time I've ever REALLY maxed it out was a couple of weeks back when I switched cloud backups and had to upload just over half a terabyte (managed a sustained (90Mbps upload which aint bad!).
Wi-Fi 6 is nice though
I only learn by making mistakes and owning up to them - boy do I learn a lot!
