Message 1 of 2
Re: WIFI Range
I was thinking of trying a mesh Wi-Fi system to improve the range, but I am not sure if it would be worth it. The Main issue is that some rooms are quite far form the router, and running ethernet cables all around the house isn't really an option. Would a wireless mesh setup solve this or would the signal still get weaker when passing through multiple walls? Has anyone tried this and faced similar issues?
1 REPLY 1
Message 2 of 2
Re: WIFI Range
I think as has already been suggested, getting in a professional to talk you through the options is probably your best bet.  You might be surprised at the wired options that are actually available in most larger properties.  Certainly with consumer grade mesh equipment you could have issues with isolating clients from each other.
As an example:  Done properly, running one or two lethernet lines (they can be pretty well hidden) up the outside of the property, into the roof space, and then to a couple of wireless access points in the ceiling could be an option - again though best get anything done professionally.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
