Message 1 of 7
Re: connection stability issues
I’m having connection stability issues with my Smart Hub 2. Speeds are good, but the connection drops randomly. I’ve tried unplugging all devices and BT refreshed the line, but the problem persists. Any suggestions?
6 REPLIES 6
Message 2 of 7
I moved your post to start your own thread so replies will apply to your problem which may not be same as previous poster's problem
Is your hub still connected to internet, hub light blue, and it is the wifi that is dropping giving message 'no internet connection'
Message 3 of 7
Not sure if you got this fixed but had same issue. An engineer cane and did a factory reset in the admin side. There was an update needed engineers are going round the country doing these updates. Can check my profile for the post I made.
recently I started getting it dropping again intermittently. Very annoying. It had been perfect for a about a month now dropping before the recent ones thoug
Message 4 of 7
I have absolutely no idea where you got that idea from, nobody is 'going round the country doing updates' . Updates are automatic and remotely applied.
Neither is there any way an update will cure stability issues that are probably a line problem.
Message 5 of 7
Engineers are with similar connection dropping problems. Literally had an engineer say this you little keyboard warrior haha
Message 6 of 7
I'm no keyboard warrior, I'm someone with many years experience that has far more knowledge than the clueless 'engineer'.
You believe whatever you want
Message 7 of 7
I'm sorry but there are no engineers going round the country just fixing connection problems.  I think you were just told a story which satisfied you as he left.  if problem has returned didn't do a very good job
