Message 1 of 14
Re: connection stability issues
when I go to BT Smart Assistant
and run a test, test results say "Your broadband is slow or unstable and this might be caused by your set-up"
However I have both a BT engineer and Openreach engineer visit my property and they have said everything is working properly!
13 REPLIES 13
Message 2 of 14
Other than the message you are getting to you have or have you noticed a problem?
If you have was have you noticed?
Give as much detail as possible.
Message 3 of 14
No problem, but now when I go to the hub manager 192.168.1.254 I get an error page
400 Bad Request
No request found.
Message 4 of 14
See this thread about the changes in accessing the BT Hub's management pages.
BT Hub Manager - recent changes - BT Community
Message 5 of 14
I cannot see thread regarding
accessing  the hub manager 192.168.1.254 and the error page
400 Bad Request
No request found.
Message 6 of 14
My mistake, I posted the wrong link in my last message. I have posted the correct one now.
Message 7 of 14
sorry I do see this?
Message 8 of 14
I am getting this message (attaching screen shot) I have restarted Smarthub but still same message!   Any ideas?
Message 9 of 14
... when I go to the hub manager 192.168.1.254 I get an error page
400 Bad Request
No request found.
Any different if you specify 'https' in front of the router's IP address? i.e. https://192.168.1.254
Message 10 of 14
When I go to https://192.168.1.254 I get this page.  See screen shot below
