Message 1 of 4
Replacement router
BT are sending me out a replacement router, due to fluctuating speeds, (both Ethernet and wifi). If I change the network name to the same as I have it now, plus the same password, will all my device reconnect without having to set them all up again?
3 REPLIES 3
Message 2 of 4
Re: Replacement router
Message 3 of 4
Thanks liquorice.
Anonymous
Not applicable
Message 4 of 4
Yes he's good for allsorts
