Message 1 of 2
Replacing Smarthub 2 - Router Compatibility?
I’ve had loads of minor issues with my Smarthub 2 (hit and miss connection to my phone when I try to log into it, random wi-fi dropouts etc) so I’m thinking of swapping it out. I have super fast broadband (box on the wall outside with cable into room into a small box - modem? and then into the Smarthub).
Will the ASUS TUF Gaming AX3000 work if I swap out the Smarthub 2 and leave everything else ‘as is’?
1 REPLY 1
Message 2 of 2
Re: Replacing Smarthub 2 - Router Compatibility?
I’ve got the ASUS GS AX3000 ROG gaming router with my BT 900 fibre and it works just fine.
