Message 1 of 8
Ring Devices all offline..
Everyone elses Ring devices all offline too when using BT?
Looks like its connected to the widespread Backbone routing issue.
But yeah this needs fixing asap
7 REPLIES 7
Message 2 of 8
Re: Ring Devices all offline..
Hi there
Same issue here. What is the backbone rooting issue you refer to or do you know where i can find more info? Thanks.
Message 3 of 8
Actually ignore my previous message as I’ve found another post with some info.
Message 4 of 8
Yes same issue with Ring devices
Message 5 of 8
Mine have literally come on at around 15:30. Hope yours won’t be far behind.
Message 6 of 8
Thank you, we're back online 🙂
Message 7 of 8
Thanks @DeeS77 and @JMo for the update.
I'm glad to hear you're up and running again. @bogey_man50 is there any change with you?
Cheers
David
Message 8 of 8
Yes all back online now thanks!
