Message 1 of 5
Ring Door Bell
I have a Ring Door Bell 2 and my BT Smart Hub 2.  They were working perfectly fine until abnout 3 weeks ago when the door bell discharged. Since then it is not connecting to the internet. I have tried everything i have read through the forumns including trying to connect at a different location where is worked straight away. Any help is greatly appreciated.
I have tried everything and now stuck.
1. Fully charged.
2. Reset the hub.
3. Tried switching off 5GHZ
4. Factory reset
5. BT Helpdesk updated the hub.
Tags (2)
4 REPLIES 4
Message 2 of 5
Re: Ring Door Bell
@nikhilmistry
Welcome to this user forum for BT Retail phone and broadband customers.
Have you tried a factory reset of the BT Home Hub?
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Connection issues can be caused by the home hub running out of internal connections. A normal restart does not fix that.
Message 3 of 5
Re: Ring Door Bell
have you tried resetting the ring door bell back to factory and start as new
https://support.help.ring.com/hc/en-gb/articles/4405018926740-How-to-completely-reset-your-Ring-Vide...
Message 4 of 5
Re: Ring Door Bell
@nikhilmistry
You tried turning the 5GHz off, but have you tried manually changing the 2.4GHz channel?  It may be that there's local congestion on the WiFi channel being used.
Message 5 of 5
Re: Ring Door Bell
This has worked, changed to channel 6 and connected straight away. Didn't need to switch off the 5GHz.
Thank you 🙂
