Message 1 of 3
Ring door bell
Hi I have the ring doorbell 4 duel band and im wanting it connected to 5ghz wifi put it just stays on 2.4 no matter how close i get to the router , has any been able to connect it to 5ghz thanks
2 REPLIES 2
Message 2 of 3
Re: Ring door bell
you can turn off the 2.4ghz wifi in hub manager then connect the ring to 5ghz but when you re-enable the 2.4ghz wifi the ring may just change as 2.4ghz stronger signal
Message 3 of 3
Re: Ring door bell
The obvious question is why does it matter which band it connects to as long as it works. Surely it will select the strongest signal.
