Message 1 of 5
Router security
How do I set my smart hub to WPA3 or WPA 2 (AES) as recommended in my iphone settings? It reckons WPA2 (TKIP) isn’t secure. It’s all gobbledygook to me….🤔
4 REPLIES 4
Message 2 of 5
Re: Router security
You can't change it, just ignore Apple's usual paranoia.
Message 3 of 5
Re: Router security
Turn off WPS and UPnP if you're concerned about security.
Message 4 of 5
Re: Router security
Thanks for your help!👍🏻
Message 5 of 5
Re: Router security
Thanks! 👍🏻
