Message 1 of 36
Setting up guest wifi
Hi, how do I set up a guest wifi on my BT Hub 6 router ?
Thanks,
Cliff3
35 REPLIES 35
Message 2 of 36
Re: Setting up guest wifi
You can't. It does not have that facility.
Message 3 of 36
Can I not set up a guest WiFi using my My BT account ?
Neil
Message 4 of 36
Hi distinguished Sage, can I not use my My BT account to set up a guest WiFi ?
Cliff3
Message 5 of 36
No
Message 6 of 36
O.K. so would I have to get a different router to set up a guest WiFi then ?
Cliff
Message 7 of 36
Message 8 of 36
Remember if you have digital voice or will get digital voice then the hub has to be the first connection to the internet and then any third party router
Message 9 of 36
O.K. thanks. - you don't happen to know what sort of router would allow me to set up a guest WiFi do you ?
Message 10 of 36
One way to do this is to use a WiFi extender that has its own separate WiFi SSID that it broadcast compared to the SSID it connects to the router using.  Even better if you can connect one to the router using a cable, as then not only can you use a different SSID, but even different WiFi channels!  And if it's a proper guest network, it's easy to turn on and off!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
