Message 1 of 3
Setting up smart hub before digital voice switchover
Hi,
I am due to be switched over to digital voice on 12/3/25 and have today (8/3/25) received a Smart Hub 2 to replace my Homehub3.
Can I set up the new Smarthub before the switchover date for internet use, and plug in the phone on my switch date? Will the internet still work if I swap devices early?
Any help gratefully received
2 REPLIES 2
Message 2 of 3
Re: Setting up smart hub before digital voice switchover
You can set up the new SH2 whenever you want and your internet will work.  You may if you have a number of wireless devices  change the SH2 SSID to that of your existing hub and also change the wireless password to your existing password and that way when you connect the SH2 to internet then your devices will reconnect to the hub without a problem
You don't need the SH2 connected to the internet to make these changes just powered up
Message 3 of 3
Thanks for the quick reply 🙂
