Message 1 of 17
Sign in to wifi network
My smart hub 2 has been fine until but overnight it now says important message sign into wifi network and gives me bt or ee option when i sign into bt there is just my account no issues, i got engineer in who said there was nothing wrong so spoke to bt who said my router is unsupported now they will send a new one but i have plugged in my old router and that says the same so does anyone know what is the issue as when i get the new router that will probably as say sign in to network.thanks
Tags (1)
16 REPLIES 16
Message 2 of 17
Re: Sign in to wifi network
Where does it say "Important Message sign into WIFI network"?
Are you still able to use your Internet as normal?
Where are you trying to sign into "WIFI Network"
Message 3 of 17
Hi thanks for reply no i have no internet for 3 days, the sign in page appears when I am trying to get on the internet. It says sign in for important announcement but BT say there is nothing on my account but the router is unsupported, i thought i had been switched to ee and not been told but apparently not.
Message 4 of 17
What type of BT hub do you have?
Are there any lights showing on the BT hub and if so what are they?
Have you tried searching for wifi networks in your devices wifi section and can you see your BT hubs SSiD (name). the name is on the label on the hub.
If you can see the name is it showing as connected?
If it is not connected what happens when you click on it?
Can you enter the wifi password showing on the hub's label if it is not already entered/connected?
EDIT:
See the following link how to connect to the BT Hub.
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-can-t-connect-devices-to-my-wi...
Message 5 of 17
@suzanne5  It sounds as though you are trying to connect to the BT/EE public WiFi rather than your home network WiFi.  There  is nothing within the router to generate  a message.
Message 6 of 17
It does indeed look as though you're trying to sign onto the BT/EE public WiFi.
Instead of this, look for your Hub's WiFi name (its "SSID" or "Wireless Network") which will be on the pull out tab at the back of the hub. Open WiFi settings on your device and look for this SSID and click on it. Then enter the "wireless password /key" that's also shown on the pull out tab (NOT the "Admin Password").
That should get you reconnected.
Message 7 of 17
It is not this i am using everything the same name password etc but still saying sign in wifi network
Message 8 of 17
Please can anyone help me with this?
Message 9 of 17
@suzanne5  You state you’ve had no internet for 3 days, have you connected your router to a PC or laptop using an Ethernet cable to see if you still have internet?
If you have, then obviously the problem is a WiFi only issue. You could then enter the router settings via its web page, disable WiFi, reboot the router and then re-enable WiFi and see if that solves the problem.
Message 10 of 17
Hi thanks I dont have pc to check, BT have sent a new hub but it is obviously doing the same thing
