Message 11 of 22
Re: Sign in to wifi network
what device are you using to log into your BT hub?  if you connected the new BT hub then you would need to change your log in to new hub SSID (name) and wifi password to that of new hub or did you change the new hub SSID and wifi password to that of your existing BT hub?
Message 12 of 22
Apparently there is a back end restriction on the acc no one from BT will remove because its not showing but EE say it is there so where do i go from here at wits end with BT
Message 13 of 22
have you tried logging into your MYBT as there should be something there about any account problem.
you didn't reply to my last post with the information which may help     also when you connect the hubs are the hub lights blue?
Message 14 of 22
Yes the lights are blue, BT have put a restriction on this acc for no one knows why and ofc no one has seen this problem ever before. It's digusting there is a pensioner here and now we have no phone and no internet the way BT have no clue how upsetting this is. It is a back end restriction and no one is dealing with removing it.
Message 15 of 22
Have you by any chance had a notice telling you that you have to move to BT digital voice or risk losing your connection, which you have chosen to ignore?  If so, then you need to contact the number in that communication to arrange a switchover, or explain why a special exemption should be made for you!  BT are now trying to push the point home, by restricting the services to those who have ignored previous communication, as some legacy services are due to be retired on Jan 31st 2027!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 16 of 22
Message 17 of 22
Thank you yes we have already switched to digital voice.
Message 18 of 22
Could some pls escalate this as I need BT to action it and I cannot get anyone to help me.
Message 19 of 22
Good morning, @suzanne5
I definitely want to make sure we point you in the right direction for getting this sorted.
Just to be sure, can you please confirm if your bills are fully up to date at the moment?
Also can you let me know the name of the exact WiFi network that you're trying to connect to here?
If you haven't been moved to EE, which it doesn't sound like this is the case, the only reason you would see EE mentioned is if you were trying to use public WiFi.
Peter
Message 20 of 22
Hi thank you EE have sorted for me. Yes!! And it was error on their side completely.
