Message 1 of 2
Sky Q Network Connection
Having real issues with my Sky Q box maintaining a signal with my BT Hub, also can't reset the hub via the BT app?
1 REPLY 1
Message 2 of 2
Re: Sky Q Network Connection
have you tried changing the hub 5ghz network from auto channel select to a fixed channel either 44/48 as the SKY Q uses channel 36
