Message 1 of 10
Slow broadband
 Been with BT broadband for a month.  Complained of slow speed.  Engineer visited and said he'd fixed it.  He hadn't.
Registered athe faukt again on 12th August.  Still not fixed.  Have been informed that my home setup is OK but there's a "Network fault" that they are looking into.  No progress.
9 REPLIES 9
Message 2 of 10
Re: Slow broadband
If you only joined 1 month ago I assume you are on FTTP  so which package do you have
Is your download speed that is the problem so are you using WiFi or ethernet to connect your devices.  What speeds using ethernet do you get if you you run  fast.com
Message 3 of 10
Re: Slow broadband
I don't know what FTTP is.
I'm connected via WiFi.  Ethernet not practical.
The engineer who visited said there was no problem with my setup and that there was a problem on the network.
Fast.com was showing 1.73 download in WiFi.
Message 4 of 10
Re: Slow broadband
FTTP  - fibre to the premises/home as opposed to FTTC - fibre to the cabinet and copper to your home
There are no guarantees on download speeds and no ISP will guarantee connection speed over WiFi due to the problems with interference.  You need to try with ethernet connection at least for a test to show speed
Message 5 of 10
Re: Slow broadband
It's FTTC.
The engineer who visited tested my WiFi connection and assured me it was fine and BT have subsequently said my system is fine, that it's anetwork problem that Openreach were looking into.
I don't accept that a provider can offer a service that claims to offer up to 32 Mbs and averages below 5Mbs.
I had the same system (FTTC) in my previous property with no problem.
Every communication I've had from BT whether via Chat, Telephone or email has just tried to place the blame on me and has come up with a variety of excuses.
Message 6 of 10
Re: Slow broadband
All speeds quoted by BT are connection speeds to your router not download speeds to your device.  Have you tried using a WiFi analyser on your phone to see what channels are in use by your neighbours then go to hub WiFi and select a free or less congested channel?  Are you WiFi devices connecting to 5ghz network not the 2.4ghz?
Message 7 of 10
Re: Slow broadband
Can you please recommend a WiFi analyser for Android which isn't rendered unusable by ads  ?
Message 8 of 10
Re: Slow broadband
there are plenty on play store  I use Wifi |Analyser app
Message 9 of 10
Re: Slow broadband
The WiFiAnalyser is open source . Its the one by VREM Software Development.
https://vremsoftwaredevelopment.github.io/WiFiAnalyzer/
Message 10 of 10
Re: Slow broadband
Found it.  Thank you.
