Message 11 of 11
Re: Smart Hub 2 Ethernet problem
Hi @silverbantam sorry that you're now getting this IPC error.
If you have full fibre try power cycling the ONT first.
Check your broadband speed is ok, restart your router and then the TV box and see if that resolves the error.
Cheers
John
