Message 1 of 10
Smart Hub 2 only giving 100 mbps on ethernet
Hello there. I've just got my full fibre 900 packaged installed and activated today. Speeds are fine on wifi around 700mbps
On my pc it's capped at 100mbps. I am using a cat 7 cable and have set the network adapter from auto negotiation to 2.5gbps. I have also tried using all the ports available on the smart hub 2 and my pc. Network drivers are the latest version and I've reset the hub and restarted my pc multiple times to see if that would help. Nothing has worked. How can I resolve this issue?
9 REPLIES 9
Message 2 of 10
Re: Smart Hub 2 only giving 100 mbps on ethernet
Is your PC connected straight to your hub or via a switch?
Message 3 of 10
is that connection speed or download speed  check here  fast.com
Message 4 of 10
fast.com showed a download speed of 92mbps on my pc as expected 😞
Message 5 of 10
Apologies for the late reply on this. Yes the pc is connected straight to the hub with the cat 7 cable
Message 6 of 10
@MohammadA1i
If your PC network card is only showing a physical connection of 100mbs, it will probably be an issue with auto-negotiation, and slight temperature changes can cause timing differences and corrupt the Ethernet Link Pulse. See https://en.wikipedia.org/wiki/Duplex_mismatch
If you fit an Ethernet switch between a LAN port on the home hub, and the LAN port on your computer, the problem should stop, as the switch will match the two rates.
Like this one https://www.tp-link.com/uk/business-networking/litewave-switch/ls1005g/
About £9.50
You would only use two of the ports, and it would give three extra ones if you needed them.
Message 7 of 10
Thank you for your reply. So what you're saying is I will need to connect a cable going from the hub to the switch and then connect another cable going from the switch to my pc. Is that correct?
Message 8 of 10
Yes, that is correct.
This issue has been reported before, and an Ethernet switch has cured the problem. Ethernet switches are capable of matching different speeds and compensating for timing differences, as they have internal buffers.
Message 9 of 10
Turns out it was actually the cable that was the issue. Using the ethernet switch didn't help so I went ahead and ordered another cable, a round cat 6 cable this time as lots of people on other forums suggested not to buy flat cables or cat 7/8 cables due to them having issues with providing gigabit speeds. Regardless thanks for the help. It was much appreciated 😁
Message 10 of 10
The flat cables may not have been fully wired, which is needed for Gigabit speeds. Depending on where you bought the Ethernet switch, you may be able to get a refund. Either that, keep it just in case you need more Ethernet ports in the future.
