Message 1 of 3
Smart hub 2 and access points
I've recently swapped from my home hub (3 I think) and all in the house is working fine but the tp link Wireless N Access Point TL-WA801N I had working in my out building is now not working when connected as before using ethernet.
what am I missing in set up?
2 REPLIES 2
Message 2 of 3
Re: Smart hub 2 and access points
Try a different Ethernet port on the Smarthub.
Did you change the WAP to have the same SSiD as the new Smarthub.
Message 3 of 3
There is no setup to do but just make sure if you are using port4 that it hasn't been configured in full fibre (FTTP) mode.
