Message 1 of 3
SmartHub1
Does anybody know if i can use a spare smarthub1 as an ethernet / wifi hub if i connect it to a WAN port of my smart hub2. Ideally I want to use the spare hub in another room and if possible be able to use it for WiFi as well ?
Any suggestions are welcome
2 REPLIES 2
Message 2 of 3
Re: SmartHub1
You can use it as a wireless access point with 3 Ethernet ports by connecting the 2 hubs together LAN port to LAN port.
Give the second hub an IP address outside if the DHCP range of the primary hub and turn off DHCP.
Message 3 of 3
Re: SmartHub1
Thanks will try this once I have got the cabling done between the two rooms
