Message 1 of 3
BT Whole Home Wifi
This is my first post here, so please be gentle!
I currently have standard BT Fibre broadband with a max speed of around 28 Mbps and I have the Smart Hub 2.
I live in a terraced house and I um unable to get a decent WiFi signal there.
I have purchased the BT Whole Home 3 pack to attempt to improve the signal to the rear of the house.
I was looking at the Google Nest WiFi but understand from searching the internet, this will not work with the BT hub.
My question is, once the Whole Home discs are set up, can I still utilise the other Ethernet ports on the hub?
I understand the first disc will be connected to the hub via ethernet but I need to keep my switch connected to the hub as my NAS and Sonos run from it.
This is probably a fact question but would rather know before I start to set up the WiFi discs.
Thanks in advance.
2 REPLIES 2
Message 2 of 3
Re: BT Whole Home Wifi
Yes, of course you can.
Message 3 of 3
Many thanks @licquorice
