Message 1 of 2
Split bands On BT Smart Hub
I have a first gen BT Smart Hub 6 and used to be able to split the 2.4Ghz and 5Ghz bands (Which i have Done) although when i now go into advanced wifi options the option to split Bands is missing even though the bands are still split from before.
I believe the SH2 has had this removed but the Smart hub 6 should still be able to split according to BT website
The amount of basic settings the BT routers are missing is quite shocking
1 REPLY 1
Message 2 of 2
Re: Split bands On BT Smart Hub
You should still be able to give the 2.4/5 GHz networks different SSID if using hub 6 but you cannot split networks in the SH2. This has been covered numerous times on the forum
