Message 1 of 3
Strong Atria Home Mesh1200 +Smarthub2 + 2 computers + smartphone +security camera
I have installed a 2 node Wifi mesh system; I can only access the WebUI using my android phone.
I have set the allowed IP range to match the range in the Smarthub router.
When it comes to setting up the Wireless I am  not sure which  option to use-Gateway or Bridge -i don't really understand  what they are anyway.
The two desktops and the printer don't show up in the  mesh WebUI, although the mesh nodes show up in the Smarthub2 router UI. Obviously I can access the Smarthub UI from the desktop, but I cannot access the mesh UI from the desktop, even though the IP shown in the Smarthub for the mesh controller is 192.168.1.xxx.
What am I missing?
2 REPLIES 2
Message 2 of 3
Re: Strong Atria Home Mesh1200 +Smarthub2 + 2 computers + smartphone +security camera
Gateway and bridge seem strange terms to use. Usually it would be router or access point modes.
Presumably Gateway=router and bridge=AP
Access point mode is the simplest option if you are also using the BT hub.
Message 3 of 3
Thanks licquorice.
If these terms seem strange to you it's all greek to me.🤣
Thanks for your advice.
