Message 1 of 2
Dual wan
Hi I am currently with vm gig1, it is terrible for gaming and currently there is a packet loss issue due to upstream noise on local node, my router asus gt-axe16000 can run dual wan. Would I be able to order a bt connection just for gaming and would there be any issues. I would just leave vm but I live in a flat and cannot get fttp or high speed packages, or I would buy immediately. If anyone in the community can help or have any suggestions what to do I would much appreciate.
Regards
Viper-t
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Dual wan
No reason that you can't have multiple suppliers at the same address, particularly if one of them is VM which has it's own infrastructure independently of Openreach.
If only FTTC is available to you, you will need a standalone modem to connect line to your router.
