Message 1 of 2
Struggling to connect sonos play 3 to my new Smart Hub 2. No problems with any other device
1 REPLY 1
Message 2 of 2
Re: Struggling to connect sonos play 3 to my new Smart Hub 2. No problems with any other device
Are you trying to connect to 2.4ghz network? If so as your device is having problems try turning off the 5ghz network in hub and after device connects then re-enable the 5ghz
