Message 1 of 21
Please confirm my thinking
Hello clever people.
I’ve been reading the forum posts for a while.
I have recently moved in to a new build with BT fibre 900.
it is ok but there are definite drops around the house ( and no signal to speak of in the garden).
https://ibb.co/3k657vP
https://ibb.co/KGZht7k
I’m hoping that two images have appeared.
one is showing what I think confirms I have FTTP?
The other is the new setup I’ve ordered.
I don’t need digital voice at all.
do I simply unplug the bt hub and replace is with the deco hub? I’m guessing I need to log in with a BT username and password?
then I’m hoping it’s a case of plugging in the others and playing ?
20 REPLIES 20
Message 2 of 21
Re: Please confirm my thinking
Yes to both questions.
Set the Deco WAN port to PPPoE username [email protected] and password BT
Message 3 of 21
That’s for the quick reply.
I don’t know if what I’ve gone for is overkill, but I’ll let you know how it goes
Anonymous
Not applicable
Message 4 of 21
Message 5 of 21
Well spotted
Message 6 of 21
Unless it's been changed you can use any prefix to @btbroadband.com
Message 7 of 21
Yeah, I think that's still the case
Message 8 of 21
Just a thought:
is it PPPoE ( Ethernet) just from the ONT to the hub?
I don’t want Ethernet cables from hubs to APs and am hoping it’s Wi-Fi to those points
Message 9 of 21
ONT LAN --> main Decco's WAN.
I see you do have a patch panel though. Do you have a ethernet ports in other rooms?
The decco supports a WiFi backhaul between each node but you can also do ethernet backhaul too.
Message 10 of 21
The old saying, if all else fails "check the Instructions".
See the attached link
 Deco XE75 | AXE5400 Tri-Band Mesh Wi-Fi 6E System | TP-Link United Kingdom
