Message 1 of 5
TP-Link AX5400 Wi-Fi 6 Router and BT Smarthub2
Just moved to Fibre 2 on BT from Sky and trying to marry it to my existing home network with no success. Has anyone else had the same or similar issues? I've added connection type PPPoE with the [email protected] user ID and both devices are connected to each others WAN ports via Ethernet cable. They don't appear to be talking!
4 REPLIES 4
Message 2 of 5
Re: TP-Link AX5400 Wi-Fi 6 Router and BT Smarthub2
Where to start
You don't connect 2 routers together wan to wan for starters, either LAN to WAN and have 2 networks or LAN to LAN and use the second router as a wap.
In either case, the PPPoE session is carried out by the BT hub not the TP link.
Decide which you want to do and post back
Message 3 of 5
Thanks for your help. WAP is what I'm looking for, I've connected them LAN1 to LAN1. What do I need to do next to utilise my Tplink router rather than the homehub wifi? Tplink router can't seem to establish an internet connection
Message 4 of 5
Give the TP link an IP address outside of the DHCP range of the hub such as 192.168.1.10 set the gateway to 192.168.1.254 and disable DHCP
Message 5 of 5
This works tha ks for your help
