Message 11 of 11
Re: Teckin smart plugs wont connect to hub
Thankyou
I think all I wanted to know was what would happen if I turned off the 5GHz on the router, well actually nothing happened, everything carried on as normal.
The plug is now installed and 5GHz is back on.
Athough now it all works, i'm beginning to think i wished id saved my money!
