Message 1 of 5
Thinking of buying a Netgear Orbi RBK30
I have a Smart Hub 2 and following a visit by an engineer was advised to ditch Powerline adapters which can compromise performance and go for a WiFi mesh system instead.
I did consider the BT Whole Home Mesh Wi-Fi system. As these disks only have one Ethernet port I have looked around and wonder if the Netgear system would be better as the Orbi router has 3 LAN Gigibit Ethernet ports, and the satellite unit has 2 Ethernet ports.
Also the Netgear system uses WiFi 6, which the BT devices do not. I would not want to use the Netgear router as a router.
Am I likely to run into problems if I use the Netgear system or is it as simple to set up and use as it appears to be?
4 REPLIES 4
Message 2 of 5
Re: Thinking of buying a Netgear Orbi RBK30
try using search facility for Netgear Orbi
here is one result from many
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Netgear-Orbi-Mesh-SmartHub/m-p/2245024
Message 3 of 5
Thanks, I did try a search and did not find anything which seemed relevant.
The link which you posted relates to someone who has FTTP. I have copper wire connecting to my home so the fibre does not reach my house so I guess that I do not have FTTP or FTTH.
Message 4 of 5
If you are using the Orbi in Access Point mode, just connect it to the SH2 LAN port to LAN port.
Message 5 of 5
Thank you, I will try that.
