Message 21 of 27
Re: Tp-link Archer vr600 won’t connect to the internet.
Why did you want it in the first place, its a very old device?
Message 22 of 27
Return the VR600 to the retailer, as its not suitable for your usage, unless you use it as a very expensive wireless access point.
Message 23 of 27
I was told it’s better to use than the normal smart hub 2 as they’re dreadful apparently
Message 24 of 27
You were told nonsense.
Message 25 of 27
Draytek appear to do a number of G.Fast devices BUT they start at £200+.
Message 26 of 27
Openreach are no longer providing G.Fast, and anyone renewing their contract will either be offered FTTP if available, or VDSL Fibre 2, up to 80Mbs.
Anonymous
Not applicable
Message 27 of 27
If you bought it online just send it back.
Routers supporting GFast are very thin on the ground but I believe you could add a separate modem (MT992) from Ebay. No experience of these or GFast though, so you'd have to do your own research to see if buying one is a good idea. Unless someone here can confirm.
What exactly are you trying to achieve by replacing the SH2?
