Message 1 of 27
Tp-link Archer vr600 won’t connect to the internet.
Hi guys ,
so I have the Magic socket 5c box that is connected currently to my bt smart home WiFi router. I purchased the vr600 , plugged it into both the wan & wsl connections (obviously on two different occasions) set everything up as suggested on numerous forums ( isp BT_VDSL - account username [email protected] password - BT , yet as soon as I do all that it says I have no internet connection?
Tried both wan and the broadband cable port on the VR600 , nothing. I’ve been researching and trying to connect for over 2 hours , safe to say I’m baffled as to why it won’t connect considering as soon as I put my bt hub back on it connects no problem.
any ideas would be amazing.
26 REPLIES 26
Message 2 of 27
Re: Tp-link Archer vr600 won’t connect to the internet.
What are you actually trying to do its not clear.
Are you :
a) Trying to use the vr600 directly connected to the master socket
b) Trying to use the vr600 in conjunction with a BT Smart Hub 2 as an access point
c) Trying to use the vr600 in conjunction with a BT Smart Hub 2 as a router.
Message 3 of 27
Message 4 of 27
But only required if connecting directly to master socket.
Not sure if the OP is connecting to the master socket or the SH2.
Message 5 of 27
Agreed, it's not clear, but I read it as he is trying to connect the VR600 to an NTE5
Message 6 of 27
Hi sorry , I’m trying to connect the vr600 directly to the master socket 5c
Message 7 of 27
Apologies I did actually put this in .com I miss typed .co.uk in the OP
Message 8 of 27
As @Les-Gibson  says you have used the incorrect PPPoE username.
The NTE 5c connects to the DSL socket of the vr600, make sure connection type is BT VDSL
Message 9 of 27
Are you sure you have a VDSL service and not G.Fast, the vr600 won't work on G.Fast
Message 10 of 27
Not sure if I’m honest, don’t know how I’d even find that out , the bt page said I had FTTP if that helps, my old router is a smart hub 2
