Message 1 of 3
Turn off Wifi on 4k BT youview box
All sorted 🙂
2 REPLIES 2
Message 2 of 3
Re: Turn off Wifi on 4k BT youview box
@cjetsy wrote:
I have a BT 4k youview box and is connected via ethernet, but it appears to be giving off wifi as well BTWi-fi and BTWiFi-X. (even with the BT router switch off I can still see it and its not my neighbours).
I have a complete Unifi AP network and I can see it jumping channels all the time which is causing small issues with my wireless.
Has anyone seen this and manged to disable it, I can see anything in the menus ☹
What leads you to believe it is not emanating from your neighbour?
Does it disappear if you switch off the YouView box, I suspect not?
Message 3 of 3
