Message 1 of 4
UPS and FTTP
Hi
I have an issue which I hope someone can help with.
I currently have FTTC broadband with BT.
Today I upgraded to full fibre, partly as I have a requirement to have a stable internet connection with no outages. I currently have a UPS connected to my router and PC's to prevent any unplanned outages from power cuts / trips.
I planned on moving the new hub upstairs and connecting it to the modem (in the hall) via Cat 6 cable. It can then stay connected to my UPS, as my current router currently is.
I didn't realise at the time of upgrade that the modem in the hall will also need power. Therefore if there is a power failure / trip, I imagine that the connection will drop, thus making the UPS connected to the hub useless for this purpose.
So, a couple of questions:
In the event of power failure, does the battery backup on the modem activate quickly enough to prevent any disconnection at all, in the way a UPS does, or does it take a second or two to kick in ?
If I contact BT and they will not now provide a battery back up unit, are they available to buy, and are they specific to a particular make of modem (I believe that BT use more than one manufacturer) ?
3 REPLIES 3
Message 2 of 4
Re: UPS and FTTP
BT can supply a bbu for the ont at a cost to yourself
I believe the one they use will only last an hour. If you have a ups set up already you could have it plugged into that .
Message 3 of 4
Re: UPS and FTTP
there is no battery back up on your ONT so if power cut then no internet
Message 4 of 4
Re: UPS and FTTP
I appreciate that it is very late but BT will sell you a UPS solution for the ONT:  Cyberpower Back-up for BT Digital Voice service (FTTP)
See also this thread: https://community.bt.com/t5/Home-phone-including-Digital/UPS-solution-for-ONT-and-SH2/m-p/2285458#M8...
Philip
