Message 11 of 14
Re: Unable to find HH6 USB storage device on my network
I have no trouble mapping it.
Message 12 of 14
Hi all,
So I have managed to get this to work.
I am unsure as to which route worked as I tried two things at the same time.
I rebooted the laptop whilst also formatting the USB stick to NTFS. The drive is now seen on the network via the "run" command and I have successfully been able to map the drive!
Thank you all for your assistance with this very simple yet frustrating task! 🙂
Mike.
Message 13 of 14
Glad you got it sorted.
Message 14 of 14
Thanks bud.
