Message 1 of 2
Used password on EE WiFi-X"
I used my password trying to login into EE WiFi-X" by mistake, instead of my own ssid. I believe this EE WiFi-X" is someone else's as I have opted. Do I need to change my password, would it be gained by a third party ?
1 REPLY 1
Message 2 of 2
Re: Used password on EE WiFi-X"
The EEWIFI-X is probably coming form your own router and is same as BTWIFI-x  you don't need to change password
