Message 1 of 3
Using a TP-Link Archer C7 AC1750 to replace my smart hub 2
Hi, I needed to set up a guest network so have connected this TP Link AC-1750 router instead of the smart hub 2. For some reason it won’t connect to the internet. I have changed PPPOA to PPPOE and filled in the username and password I found on here. Anything else I n ed to change to establish connection? This is new territory for me so all help appreciated, thanks
2 REPLIES 2
Message 2 of 3
Re: Using a TP-Link Archer C7 AC1750 to replace my smart hub 2
@MB74
That is just a wireless router and will only work if you have a separate modem, or if you have an FTTP connection.
It will not work on a FTTC (DSL) connection. without a modem. It has no DSL port.
Message 3 of 3
Thanks, would an option be to connect it to smart hub? Is that possible?
