Message 11 of 19
Re: Using a TP-link AX5400 (third party router) with the Smart Hub
Sorry I'm confused here!  If you are still using the TP-Link router in AP mode, there should be no IPv6 settings - it's an AP!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 12 of 19
I've changed the Tp-Link to router mode as I was curious to see if I could get it working with the Plusnet router in bridge mode. The internet works fine, speeds are normal but IPV6 does not work.
Anonymous
Not applicable
Message 13 of 19
@ttimms
Plusnet don't support IPv6, so maybe the firmware in their router doesn't? Try it in router mode without the Netgear & see if IPv6 is present then.
Message 14 of 19
If its in bridge mode it should be transparent.
Anonymous
Not applicable
Message 15 of 19
@licquorice
Agreed, but a simple thing to test. There's a trial of IPv6 ongoing at Plusnet, but I don't know if firmware was updated to facilitate it.
Message 16 of 19
I guess the other way to prove it is transparent is to put the hub back in full fibre mode and connect the Plusnet router to the WAN port of the hub.
Message 17 of 19
I've tried the Plusnet hub in router mode and it does support IPV6.
Message 18 of 19
Thought I would update this. I've bought an Asus router and it has no issues getting a working IPv6 address with the Plusnet hub router. I've read online that Tp-Link routers don't support /56 prefix which BT uses? So that probably has something to do with it.
Message 19 of 19
@ttimms
What internet service do you have because if it's full fibre then you connect the Asus directly to the ONT so no need for another device connected unless you have digital voice.
If you have FTTC then just ignore the above please.
