Message 1 of 7
Using my BT Smart Hub 2 with a TP-LINK Archer AX6000 and M5 Decos
Hi, my current set up is a BT Smart Hub 2 (wireless router), which I've connected a 'master' Deco M5 to. I then have a further 5 Deco M5 around the house and out buildings
I have just purchased a new Archer AX6000.
Does the Archer AX6000 replace the BT Smart Hub 2? Or do I still need the BT
Also, I wish to use the AX6000 plus connect the Deco M5s and make use of both the AX6000 and the Decos
Do I link the AX6000 to my existing BT Smart Hub, and then connect the Decos to the AX6000 or keep the 'master' Deco plugged into the back of the BT Smart Hub?
Any suggestions, would be welcome.
Thank you,
6 REPLIES 6
Message 2 of 7
Re: Using my BT Smart Hub 2 with a TP-LINK Archer AX6000 and M5 Decos
do you have digital voice?  if so then SH 2 need to be first connection to internet
do you have FTTC or FTTP as AX 6000 is just a router
Message 3 of 7
Any particular reason for buying the AX6000? To what purpose do you intend to use it?
Message 4 of 7
An uneducated purchase. We live in an old house with thick stone walls and I thought that if I bought a 'better' WIFI router, it would improve the situation!
Message 5 of 7
All I have at the moment, is the BT Smart Hub 2 (connected to my ISP), and the TP-Link Deco 5s
Message 6 of 7
Message 7 of 7
No, digital voice either.
