Message 21 of 24
Re: VPN not working from BT internet
Could this help?
Routing tables
Internet:
Destination Gateway Flags Netif Expire
0/1 192.168.1.1 UGScg en0
default 192.168.1.254 UGScg en0
127 127.0.0.1 UCS lo0
127.0.0.1 127.0.0.1 UH lo0
128.0/1 192.168.1.1 UGSc en0
164.40.218.74/32 192.168.1.254 UGSc en0
169.254 link#15 UCS en0 !
169.254.169.254 link#15 UHLSW en0 !
192.168.1 link#15 UCS en0 !
192.168.1.1 link#15 UHRLWIir en0 19
192.168.1.42 192.168.1.42 UH utun6
192.168.1.130 8a:f6:db:bb:5b:d2 UHLWI en0 684
192.168.1.135 ca:d6:fa:be:bc:6f UHLWI en0 940
192.168.1.168 90:48:6c:a2:12:ea UHLWI en0 1170
192.168.1.200/32 link#15 UCS en0 !
192.168.1.200 c8:89:f3:e4:d3:5 UHLWIi lo0
192.168.1.243 9c:76:13:7b:c9:90 UHLWI en0 1182
192.168.1.254/32 link#15 UCS en0 !
192.168.1.254 70:97:41:97:50:bf UHLWIir en0 1186
192.168.1.255 ff:ff:ff:ff:ff:ff UHLWbI en0 !
224.0.0/4 link#15 UmCS en0 !
224.0.0.251 1:0:5e:0:0:fb UHmLWI en0
229.0.0.4 1:0:5e:0:0:4 UHmLWI en0
255.255.255.255/32 link#15 UCS en0 !
Internet6:
default fe80::%utun0 UGcIg utun0
default fe80::%utun1 UGcIg utun1
default fe80::%utun2 UGcIg utun2
default fe80::%utun3 UGcIg utun3
default fe80::%utun4 UGcIg utun4
default fe80::%utun5 UGcIg utun5
::1 ::1 UHL lo0
fe80::%lo0/64 fe80::1%lo0 UcI lo0
fe80::1%lo0 link#1 UHLI lo0
fe80::%ap1/64 link#14 UCI ap1
fe80::e889:f3ff:fee4:d305%ap1 ea:89:f3:e4:d3:5 UHLI lo0
fe80::2c61:edff:fe99:f77d%awdl0 2e:61:ed:99:f7:7d UHLI lo0
fe80::2c61:edff:fe99:f77d%llw0 2e:61:ed:99:f7:7d UHLI lo0
fe80::%utun0/64 fe80::5a88:d677:945a:17d9%utun0 UcI utun0
fe80::5a88:d677:945a:17d9%utun0 link#18 UHLI lo0
fe80::%utun1/64 fe80::fbc6:2ce8:436f:1b16%utun1 UcI utun1
fe80::fbc6:2ce8:436f:1b16%utun1 link#19 UHLI lo0
fe80::%utun2/64 fe80::3f25:3b8e:ff4:1138%utun2 UcI utun2
fe80::3f25:3b8e:ff4:1138%utun2 link#20 UHLI lo0
fe80::%utun3/64 fe80::ce81:b1c:bd2c:69e%utun3 UcI utun3
fe80::ce81:b1c:bd2c:69e%utun3 link#21 UHLI lo0
fe80::%utun4/64 fe80::b2f3:debc:4979:9c91%utun4 UcI utun4
fe80::b2f3:debc:4979:9c91%utun4 link#22 UHLI lo0
fe80::%utun5/64 fe80::2ff:710d:8ed:9629%utun5 UcI utun5
fe80::2ff:710d:8ed:9629%utun5 link#23 UHLI lo0
ff00::/8 ::1 UmCI lo0
ff00::/8 link#14 UmCI ap1
ff00::/8 link#16 UmCI awdl0
ff00::/8 link#17 UmCI llw0
ff00::/8 fe80::5a88:d677:945a:17d9%utun0 UmCI utun0
ff00::/8 fe80::fbc6:2ce8:436f:1b16%utun1 UmCI utun1
ff00::/8 fe80::3f25:3b8e:ff4:1138%utun2 UmCI utun2
ff00::/8 fe80::ce81:b1c:bd2c:69e%utun3 UmCI utun3
ff00::/8 fe80::b2f3:debc:4979:9c91%utun4 UmCI utun4
ff00::/8 fe80::2ff:710d:8ed:9629%utun5 UmCI utun5
ff01::%lo0/32 ::1 UmCI lo0
ff01::%ap1/32 link#14 UmCI ap1
ff01::%utun0/32 fe80::5a88:d677:945a:17d9%utun0 UmCI utun0
ff01::%utun1/32 fe80::fbc6:2ce8:436f:1b16%utun1 UmCI utun1
ff01::%utun2/32 fe80::3f25:3b8e:ff4:1138%utun2 UmCI utun2
ff01::%utun3/32 fe80::ce81:b1c:bd2c:69e%utun3 UmCI utun3
ff01::%utun4/32 fe80::b2f3:debc:4979:9c91%utun4 UmCI utun4
ff01::%utun5/32 fe80::2ff:710d:8ed:9629%utun5 UmCI utun5
ff02::%lo0/32 ::1 UmCI lo0
ff02::%ap1/32 link#14 UmCI ap1
ff02::%utun0/32 fe80::5a88:d677:945a:17d9%utun0 UmCI utun0
ff02::%utun1/32 fe80::fbc6:2ce8:436f:1b16%utun1 UmCI utun1
ff02::%utun2/32 fe80::3f25:3b8e:ff4:1138%utun2 UmCI utun2
ff02::%utun3/32 fe80::ce81:b1c:bd2c:69e%utun3 UmCI utun3
ff02::%utun4/32 fe80::b2f3:debc:4979:9c91%utun4 UmCI utun4
ff02::%utun5/32 fe80::2ff:710d:8ed:9629%utun5 UmCI utun5
Message 22 of 24
Gateway should be 192.168.1.254, not 192.168.1.1 which is probably what Sky and Virgin use.
Message 23 of 24
@startork  you don't indicate whether that table is with the vpn connected or not. If it i then as @licquorice  says why has the 192.168.1.1 gateway been assigned presumably from your vpn server.
If the vpn at work is on a 192.168.1.x subnet and the home users are also on a 192.168.1.x subnet you are heading for longer term problems as you expand. in the short term things might work if both the work gateway and home gateway (routers) are both on 192.168.1.1 - but more by luck than design.
Message 24 of 24
@countrypaul  this was while the  VPN is connected and yes the issue most likely is because of the conflicting subnets!
I will try and move the Office LAN (and VPN) onto a seperate subnet to try and resolve the issue.
