Message 1 of 6
WIFI upload speed of only 0.2mb/s
Hi,
I had Full Fibre 900 installed 10 days ago and up/down speeds from the hub are fine (930/112).
My issue is that when I do a speed test from any device connected on Wifi I get results of (300/0.2) -  yes, that's 0.2 up. It's the same all over the house, even when a device is placed next to the router.
Wired connection is fine (600/100).
How can the download speed be so good and yet the upload speed so bad? Surely that has to be a configuration issue or software/hardware issue, rather than something like interference? What can I do to troubleshoot this?
Martin
5 REPLIES 5
Message 2 of 6
Re: WIFI upload speed of only 0.2mb/s
Hi,
Also have full fibre 900 with halo 3 & 3 of the black discs, getting 930mbs to the router but max wifi speed is 120mbs throughout the hse, 3 x technicians been with the last one saying oh well thats the best you are going to get, some days I have checked the speeds and the upload speed is faster than the download, how is this possible, copper wire and dial up from 20yrs ago seemed better than fibre, it appears you can have 1000`s mbs coming into the house but no one offers a decent wifi. False advertising to say the least.
Message 3 of 6
@Mc6PE67How can it be false advertising when full fibre is not sold as a wireless service?
Message 4 of 6
@mmc071
Are you quoting speeds for both the 2.4 & 5gHZ bands?
Have you tried changing the wifi channels from auto selection to ones that might be less congested by checking with a wifi analyser?
Message 5 of 6
So it turns out the issue was related to 2 devices, and the fix was to uninstall the wireless adapter from Windows 10 Device Manager and reboot so they are re-added automatically. Now the same machines are getting 400 down, 100 up.
Message 6 of 6
Ok, solution was not exactly as above...
After getting to the full download and upload speeds, I re-created a Hyper-V virtual switch and then found that killed both the download and upload speeds - leaving worse than I was to start with!
I found the fixes here -> https://www.tenforums.com/virtualization/183576-very-slow-up-download-speeds-hyperv-external-switch-...
Now have full download and upload speeds and is working fine with Hyper-V configured and working too.
NOTE: UNLESS YOU'RE A DEVELOPER/ADMIN THAT USES HYPER-V THEN THIS THREAD WILL BE TOTALLY IRRELEVANT TO YOU AS THE ISSUE WAS CAUSED BY HYPER-V
